injector replacement
Trying to change the injectors and having a problem. The last one on the passenger side won't come out. It hits the heater box. Whats the trick to getting it out?
Should have a couple screws in it to remove a chunk of it! dont have to remove the hole box!
As mentioned above you should be able to remove the vacuum reservoir (you'll see the vacuum line going to it) from the AC box (just need to peel back the insulation). If that doesn't give enough room, you can remove the 4 torx screws that hold the injector solenoid to the injector (that should be enough). Cheers!
