1995 psd crank no start - Ford Powerstroke Diesel Forum
Old 08-10-2012, 02:14 PM
Hello all I have a psd given to me that has been sitting a few years I put new batteries and had starter rebuilt and put a cps in you can crank all you want but wont fire puled fuel filter and cranked and bowl filled with fuel. What is next I put fresh fuel in bowl and cracked the back bolts on the head and air and oil came out after cranking
Old 08-10-2012, 02:18 PM
CSP Resident Spooby
Does the WTS light come on when you turn the key on? Any smoke while cranking?
Old 08-10-2012, 02:22 PM
No smoke and yes wts comes on and the tach moves when cranking
none of the fuses looked blown and I swaped the relays also can you plug A scanner like the bluepoint microscan into these trucks
Old 08-10-2012, 02:26 PM
CSP Resident Spooby
No smoke? Sounds like it's not getting fuel. Is it making any attempt to fire, or just cranking with no signs of life?
And you have to have a good scanner to function on these trucks. I know BluePoint makes some good stuff, I'm not familiar with the microscan though. I've only ever used Snap-On scanners on mine.
Old 08-10-2012, 02:41 PM
No sign of life there is fuel at the return line on tbe head when cranking. Where do you hook the scaner up at
Old 08-10-2012, 02:50 PM
No signs of life what would be a good basic fuel pressure tester to use I hooked mine up and got no reading but came out so not sure if my gauge is bad where do you hook a scanner up on these tricks thanks this is my first diesel so I have a lot of learning to do
Old 08-10-2012, 02:58 PM
CSP Resident Spooby
I had a lot of learning to do back when I bought my truck, as it was my first diesel as well.
I can't really help with the fuel pressure guage, as I have never had a need for one.
As for the DLC (Data Link Connector), it's located at the bottom of the dash, right below the bottom left corner of the glovebox.
Old 08-10-2012, 03:00 PM
check the IPR and ICP sensors, when you get the scanner hooked up.
Old 08-10-2012, 03:03 PM
Those are the obd 1 connector I am guessing I have the connector for the scanner stop I will try that next not sure where to start looking the hpop that fires the injectors can you test the oil pressure on that at all
Old 08-10-2012, 03:06 PM
CSP Resident Spooby
It didn't even click to me that you have a '95. I think some 95's may have had OBDII IIRC, but I'm not positive. I have OBDII, and that's where the connector is located.
And I believe HPOP pressure can be monitored through a scan tool.
