Voltage; guage looks low - Ford Powerstroke Diesel Forum
Old 08-08-2012, 03:48 AM
excuse the dumb title. I have a 97 Powerstroke with 123000 miles. When I drive the voltage sits right past the R in normal. When I switch my lights it drops in between O and R and if I use my window the needle jumps down and back up. Took the truck to a buddy and tested both batteries; one threw a bad batt and a bad alt on one battery. So I replaced the battery. It Threw good codes after but the guage still reads wierd.
P.S. Doing a tri pillar soon so I wanna solve it before I put more drawing amps in it.
Old 08-08-2012, 03:02 PM
De-rail in 3... 2... 1...
Originally Posted by Camoman92 View Post
Took to a buddy and threw bad batt and bad alt on one battery and replaced the battery..
Just not understanding this sentence.
Old 08-08-2012, 04:16 PM
sorry, I posted it before work so I was running late. I took the truck to a buddy and tested both batteries and the alternator. On one battery it threw a bad alternator code, but did not throw a bad alt code on the other; So I replaced to battery and no bad codes were thrown. The problem is still happening though.
Old 08-08-2012, 04:20 PM
i believe you should replace both batterys at the same time or the old one can kill the new one right away. and also check the big wire on the back of the alternator for corosion
Old 08-08-2012, 04:35 PM
^ Agreed. So with the engine running you are getting 14.2v at each battery?
Old 08-08-2012, 07:14 PM
I dont remember what the voltage said at my buddies but I have a multimeter that ill check again. I would set it on a DC setting right?
Old 08-08-2012, 07:25 PM
I did a 12 volt load test and the new battery read 13.8V and the other battery read 11.3V. So I will replace the other battery. Since im doing a tri pillar should I consider a new alt anyway? I was gonna have a local shop rebuild and beef it up some. I have been reading about the ones from the auto shops and they dont seem to last very long. It would probably cost less for a rebuild and probably get a better warranty.
Old 08-08-2012, 07:41 PM
At night with the headlights on do they slightly pulse? Yes aftermarket rebuilds can be iffy and quality aftermarket custom ones can be expensive. Mine is $800.
Old 08-08-2012, 08:17 PM
They only flicker if I use my inside lights or windows
Old 08-08-2012, 08:40 PM
Flicker like pulse or just dim.
