Air in system after hpop - Ford Powerstroke Diesel Forum
Old 07-27-2012, 08:04 AM
Hey Guys, just put a new hpop, fuel pump and rebuilt fuel bowl, how lond could or should it take to run right?
Sent from my DROID X2 using AutoGuide.Com Free App
Old 07-27-2012, 12:57 PM
Usually a good hard highway run will do it. Drive it like you stole it! Cheers!
Old 07-29-2012, 02:20 PM
I'm convinced it needs orings now, it still hasn't cleared up and it gets worse once it warms up. So I'm thinking once the oil thins out it lets oil get by the orings. And now its got a little blowby that it never had before. So I'm thinking its the injector orings. Let me know what yall think.
Old 07-29-2012, 07:05 PM
I'd check it when running with the VCs off to see if oil is leaking out around the base of the injectors (I'll assume you're not using oil). Cheers!
Old 07-29-2012, 07:36 PM
Im going to but first, i just realized the night i put my ts chip in is the night it started sputtering, but i found a leaking hpop line so thought that was it, then found a fuel leak and thought that was it. All thats fixed but it still sputters so im gonna pull my chip and take her for a drive. Ill post up results.
Old 07-30-2012, 03:36 PM
Still sputters, chips going back in. Do the ipr solenoids go bad?
Old 07-31-2012, 04:57 AM
Sure, they can go bad or get dirty. Cheers!
Old 07-31-2012, 05:29 AM
Ok, cause after i put the new hpop on i couldnt get it running so one of the things i did was throw the old ipr solenoid on and havent changed it back.
Old 07-31-2012, 03:26 PM
Its got probly 120 miles on it now and still sputters
Old 07-31-2012, 07:16 PM
Pulled the filter, fuel was blue.
