NEED HELP FUEL FILTER LIGHT COMES ON AND STARTS SPUDDERING AND DIES
hey guys i got a 1995 crew cab f350 4x4 5speed 215k it was a landscaping truck and they let it sit for 2 years before i got it. i have been driving it for about 3 weeks now. i bought it put new brake lines, 2 fuel filter,CPS,injection pressure regulator,fuel pump. now for the issues if i start to get on it to merge into traffic the fuel filter light will come on and if i cruise at like 55 to 60mph after about 3miles the truck will start spuddering and end up dieing and it acts like it is out of fuel but ill get out and check the fuel bowl and its got plenty of fuel. and sometimes it just dies randomly and it doesnt want to start i have to let it sit for about 10-15min then it will start. I NEED HELP GUYS it suck because i cant even take my son to daycare because im affraid of being stranded.
Check the fuel pressure at idle and you may need to check it at WOT to make sure its not dropping off. Have you checked the fuel filter again? Cheers!
I checked it saturday when i did the IPR and it was at 40psi ideling and i changed the fuel filter on saturday and i did the CPS today
You changed the fuel filter? Thats typically what a fuel filter light is for
![]() Did you drain the bowl? |
Blow the fuel lines out, sounds like they're a bit clogged
Sent from my DROID BIONIC against my will |
Yes i put a fuel filter in about 2the weeks ago when i got and i put another one in on saturday and before i put it in i pulled the fuel bowl and cleaned and sprayed carb cleaner in the ports. But i think i just found the issue all the valve covergasket plugs for the injectors are melted
ahhh that will cause a ton of problems. what a pita
ok guys i put new valve cover gaskets and the harness under the vavle cover and all new pigtails going into the vavle covers. started it up and and its runs like **** and shaking but feels like it got a cam. i hooked up my scanner and did and injector buzz test and all injectors are buzzing. HELP ANYONE THINK ITS THE INJECTOR DRIVE MODULE
try reposting this in the General Discussion area.. your not gonna get a lot of hits in the Motor Problems section
