7.3 wont start when hott!!
hi all. i have a 1995 f350 with the good ol 7.3
lately i have been having issues with it starting when hot. i have fuel pressure (60psi) and i have air. i am totally dumbfounded on what the problem is. i just changed the oil yesterday. but the wierd thing is that when i have a no start condition, if i spray a little ether it will start and stay running. it runs perfect when it starts. cranks over nice and fast. not sure if it could be the fuel pressure regulator. i have a few mods. a 6 position chip and a beans fuel system. any help i would reallly appreciate. |
Many times a "no start when hot" condition is due to bad Injection Presure Regulator (IPR) o-rings. The bad o-ring will bypass the thinner hot oil causing a no-start. If there is not enough High Pressure Oil System pressure, the injectors will not be commanded to inject fuel. The IPR O-ring kit is cheap, so it's a good place to start.
IPR O-Ring Kit (for when IPR valve replacement is not required) (Ford) F6TZ-9C977-AA (International) 1825806C92 Cheers! |
thankyou for the response. i found today that one of the two wires going to the ipr was almost broken off. so i replaced it and the connection and hoped it would fix it. but it didnt. so now im contemplating getting the o-ring kit or just buying a new damn ipr just to be safe. i found one from pensacola diesel for pretty cheap. will the ipr still cause the truck to run good even tho it wont start hot?
could be you hpop is getting weak also
