No start!!!!! Need matches!
I just replaced my fuel pump, clutch and hpop and no it wont start. Cranks all day but no start! Fuel is pumping. Been at it for 2 hours, need help now!
Sent from my DROID X2 using AutoGuide.Com Free App |
Ipr is new as well, help me out guys. In the last 2 months ive put new uvch's, icp, fpr deleted, oil, fuel filter, clutch, fuel pump, fuel bowl seals, hpop, and down pipe. Now after the hpop, fuel bowl seals and fuel pump it wont start.
start simple. do you have fuel pressure? what is it? oil pressure? what is it? all fuses/relays good? all wires connected?
Im gonna check the pressures. Im thinking its got to be the wiring harness that goes to the ipr. The wires are very soft.
Make sure the fuel bowl harness is plugged in at both ends (it gets left unplugged a lot). If you need a new one:
Fuel Filter Housing Wiring Harness (Ford) F6TZ-9S277-AA, (International) 1807333C91 (before 2/5/96) (Ford) F7TZ-9S277-AA, (International) 1825754C91 (from 2/5/96) Tousley Ford Parts will probably be the cheapest (unless you get deals locally). Cheers! |
Thanks, yeah theyre all plugged in but the wires are very soft so ill go ahead and get a new one. Its driving me insane to put 1500 in new parts and now cant drive it!
X2 on checking the pressures. Once you know you got fuel and oil pressure then we can go from there.
I wont be able to check the pressures until monday but just wanted to add, the fuel bowl filled on its own so i know its pumping fuel, and i pulled one of the oil plugs on the heads and oil started pouring out, so im pretty sure hpop is pumping too, im just thinking and praying its the wiring harness on the fuel bowl
18 mm bolt! Gear wasnt seated on the pump. Feel free to point and laugh!lol.
Hahahaha..glad you got it.
Sent from my SCH-I500 |
