engine light on and very rough idle - Ford Powerstroke Diesel Forum
Old 07-07-2012, 06:39 AM
hello all,
this morning on way home truck ran great for about 15 miles then all of a sudden it started running very rough , low on power, and engine light on. I also noticed battery gauge went low like no power. Had towed home and I've tested alternator and its fine. any ideas on where to look for a problem? its my daily driver. any and all help greatly needed!
thanks
Old 07-07-2012, 06:44 AM
have batteries tested individually. Any smoke? symptoms sound about like uvch. You're gonna have to figure out what that code is
Sent from my DROID BIONIC against my will
Old 07-07-2012, 06:47 AM
havent tested batteries but i will do that. sorry to be ingnorant but what does uvch stand for? newbie here!!! thanks for your help!
Old 07-07-2012, 06:48 AM
Check all the connections at the valvecovers. Look for burned/melted connectors and pins. Also remove the oil cap and take a sniff. If it smells like burned electrical insulation, you probably have torched connection(s) at the under-valvecover harnesses (UVCHs). Cheers!
Old 07-07-2012, 06:50 AM
thanks will check that out and post what i find!
Old 07-07-2012, 06:54 AM
just took off oil cap and it sure does smell like something burnt! sounds like thats my problem! any idea how much a fix may run me?????
Old 07-07-2012, 07:39 AM
Not much should set you back a 100$ and that's for all 4 harnesses
Sent from my SAMSUNG-SGH-I777 using AutoGuide.Com Free App
Old 07-07-2012, 07:50 AM
great!!!!!!!! i can handle that!!! any idea what causes this harness to burn up?
thanks for everyones help!
Old 07-08-2012, 06:08 PM
Usually high resistance in the glowplug wiring connections. I always suggest that if you are replacing any of the connections to the valvecover gasket, replace the gasket too. Otherwise you will most likely have the problem again shortly. Cheers!
