fuel bowl take out - Ford Powerstroke Diesel Forum
Old 07-02-2012, 07:31 PM
fuel bowl take out
my HPOP is leakinh like crazy and i bought a kit to replace the seals. but my problem is that i cant figure out how to get the damn thing out. its obvious to me that the fuel bowl needs to be pulled but i dont see any bolts to loosen on the bottom. if any body knows the best way to go about taking out the fuel bow to get to the HPOP please let me know. thanks.
Old 07-03-2012, 08:21 AM
There are two bolts down in the valley that hold the bowl to the block. Loosen hose clamps for the bowl drain, fuel pump to bowl, regulator to return line, and disconnect fuel return lines from front of heads at the regulator. Disconnect fuel bowl wiring harness at the passenger side bowl connector and disconnect the IPR. That should be about it. Cheers!
Old 07-04-2012, 08:56 AM
thanks a lot man
Old 07-07-2012, 10:02 PM
check out youtube.. there are videos showing the entire process.. on tip i can give you is that once you get the bolts and hoses off, you still need to give it a good yank to get it out.. its not gonna just fall right off cause of all the stuff around it.
Old 07-08-2012, 08:51 AM
yeah its a piece of cake! its only two bolts and alot of hose clamps. looks alot harder than it really is.
