water pump leak question - Ford Powerstroke Diesel Forum
Old 06-27-2012, 12:32 PM
My truck started leaking water. Its a constant drip even after its been sitting. It looks like its coming from the lower half of the water pump area. Do these pumps have a weep hole? Is the water pump hard to DIY?
Old 06-27-2012, 01:15 PM
Shouldn't be dripping at all. Just did mine, piece of cake. Hardest part was getting the fan off. Advance Auto has the loaner (buy, use, return) tool kit to remove the fan.
- Bill
Old 06-27-2012, 08:41 PM
Sounds like you might just have to reseal it, how many miles do you have on that pump?
Sent from my SAMSUNG-SGH-I777 using AutoGuide.Com Free App
Old 06-28-2012, 12:13 PM
De-rail in 3... 2... 1...
Is there play in the pulley? Depending on the manufacturer yes it has a weep hole.
Old 06-29-2012, 02:15 PM
Its really starting to come out. I am gonna pick up a water pump and do it this weekend.
Old 07-01-2012, 04:59 PM
Water pumps are easy to replace on the 7.3's I've replaced mine two times since new. For what it's worth replace the filler neck on the top of the Pump as that puppy needs to seal up real good as it will also leak if warped. The fan is the hardest part and I had to use a impact chesiel to get mine off as those special fan wrenches are PITA to work with if the fan is on too tight.
Old 07-02-2012, 07:29 AM
I agree,just replaced my water pump using the air chisel on the nut.Way easier than a wrench.Hardest part was making an extension to reach it. Good luck!
Old 07-02-2012, 04:48 PM
I got the water pump in and i dont see any leaks but i cant get the fan back on. what is the trick to get it lined up and threaded on?
Old 07-02-2012, 06:14 PM
Got to be doing something wrong as installing the fan is the easiest part, hardest part is getting it off? It's a lot easier if you pull the lower hose and remove the Fan Shroud because with shroud removed you have more space to install the fan and while your'e at it might want to change out the Radiator Hoses.
Again as your'e facing the engine it's counter clockwise to install that Clutch Fan assembly.
Old 07-02-2012, 06:50 PM
Actually it was easy to get off with the loaner tool from oreilly. But getting it on was the hard part until i realized that if i removed the fan belt the hub would turn. Then i only had to hold the fan in place and spin the hub to get it threaded on.
