Changed oil.. Odd parts - Ford Powerstroke Diesel Forum
post #1 of 10 Old 05-30-2012, 08:42 PM Thread Starter
95f350powerstroke*'s Avatar
When I was changing my oil today, I spun off my filter and along with it came three pieces. A spring, circular piece that almost looks like clutch material, and a washer. Do you guys have a clue what this is?
ID:	38579   Click image for larger version
1995 F-350 Reg. 4x4 7.3, TDP chip with TW tunes, gauges, DIY intake 5" turbo back
95f350powerstroke* is offline
post #2 of 10 Old 05-31-2012, 08:09 AM
superduty4x4's Avatar
Yep, its a check valve. Without it installed, there is a portion of your oil that isn't getting filtered and is just circulating back into the engine. The first model trucks had that check valve retained by staking it in and many have fallen out over the years, the later build engines had a snap ring instead. At least you found the parts, When I did the first oil change on my truck after buying it I noticed the check valve was gone.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 10 Old 05-31-2012, 08:31 AM Thread Starter
Should I take action? What did you do?
post #4 of 10 Old 05-31-2012, 12:13 PM
Patrick Feeley's Avatar
Quoted: 8 Post(s)
You can try restaking them back in (spring in first, then disc, then washer) or you can get the updated oil filter header adapter part that uses snap rings. If you need the part number for it, let me know. Cheers!
Patrick Feeley is offline
post #5 of 10 Old 06-04-2012, 01:03 PM
Sadly I have done nothing, I keep forgetting about it.
Patrick I would like that part number. Is it just the header or a whole new oil cooler? I wish I could just buy the check valve parts and install them.. don't want to do an oil cooler swap.
post #6 of 10 Old 06-04-2012, 04:40 PM
Quoted: 8 Post(s)
Here are some part numbers:
Oil Filter Header (updated snap ring retained bypass and regulator valves)
(Ford) F81Z-6881-BA
Oil Cooler Housing Gasket (front)
(Ford) F7TZ-6A636-AAA
(International) 1831666C1
Oil Cooler Header Gasket (rear; oil filter end)
(Ford) F4TZ-6A636-AA (97-up)
(Ford) F4TZ-6A636-B (96-before)
(International) 1831665C1
Oil Cooler O-Rings (one each to seal cooler at each header)
(Ford) E3TZ-6C610-A
(Ford) E4TZ-6K649-E
(International) 1807563C1, Inner 1804414C1 Outer
You'll need to drain the coolant. Might as well reseal the oil cooler while you're there as you'll be doing half of it anyway. Unless you get a good deal from your local dealer, get this stuff from Tousley Ford Parts online (usually a lot cheaper). Cheers!
post #7 of 10 Old 05-14-2013, 09:02 PM Thread Starter
How difficult Is this to do?
post #8 of 10 Old 05-15-2013, 04:31 AM
Quoted: 8 Post(s)
It's not that bad other than being messy. Cheers!
post #9 of 10 Old 05-15-2013, 11:26 AM
It can be a pain to wiggle the oil cooler out from around the crossmember too. I'd always heard that you had to jack up the engine to get it out, but that isn't the case. It'll come out with a little maneuvering with the engine in place.
sgg93 is offline
post #10 of 10 Old 05-15-2013, 07:08 PM
Quoted: 8 Post(s)
I did it with the engine in place as well. Cheers!
