Dropped plug down push rod hole please help!! - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-25-2012, 07:02 PM Thread Starter
Where does it go and what do I need to get it out??? Please and thanks I messed up bigtime and I even knew not to drop it
evanlarade is offline
post #2 of 4 Old 05-25-2012, 07:07 PM
kingranch250's Avatar
I did this my first time as well had to fish around with flexable magnet to get it out. When takin them out now I break them loose then stick a magnet to it and turn the magnet
auto merter gauges,03turbo,volant intake,SCTcustom tunes,Harley headlights,recon smoked tail/3rd break,5 inch exhaust 8inch stack,billet grille,jessejames lawsless 20's 33"mud grapplers, jesse james door handles,arp head studs,oynx gaskets,upgraded banjo bolts,river city egr delete kit,air dog 150, 08 tailgate,all lights led,mp8
kingranch250 is offline
post #3 of 4 Old 05-25-2012, 07:53 PM
Patrick Feeley's Avatar
Quoted: 13 Post(s)
I also had a similar incident. I ended up using a small, powerful magnet slug jammed into the end of some hose and just probed until I got the part (a socket) out. Couldn't see it and probably just got lucky. I did pull the rocker(s) and pushrods for the cylinder where it fell. If you do, make sure you put the engine in the 11 o'clock position to prevent "lifter jacking" (putting the engine in that position provides an oil drain path for the lifters to keep them from pumping up when pushrods are removed). Cheers!
Patrick Feeley is offline
post #4 of 4 Old 05-30-2012, 09:50 AM Thread Starter
Found it in a hole just to the bottom of the push rod hole, Xmas came early!!
