96 7.3 psd no start - Ford Powerstroke Diesel Forum
Old 05-23-2012, 06:07 PM
96 7.3 psd no start
I was driving my 96 psd let off the throttle coming downhill the truck stalled and won't restart. I got fuel in the filter housing and the cam sensor and glowplug relay where replaced a month earlier
Old 05-23-2012, 06:09 PM
Does it just crank? Does the tach move while cranking?
Sent from my Autoguide iPad app
Old 05-23-2012, 06:19 PM
CSP Resident Spooby
Sounds like the fuel bowl heater may have shorted out. If you have no tach movement while cracking and no WTS light, then thats probably your culprit...
Sent from my DROID X2 using AutoGuide.com App
Old 05-23-2012, 06:39 PM
The tach moves when cranking the wts light is working the fuel bowl heater fuse is good.
Old 05-23-2012, 06:41 PM
I'm going to replace glowplugs and harness in the morning
Old 05-23-2012, 06:44 PM
CSP Resident Spooby
The same thing happened to my buddies Super Duty 7.3 while decelerating down an offramp. His HPOP died with no warning. Hopefully it's not that bad, but it's a thought... How many miles are on your truck?
Old 05-23-2012, 06:52 PM
128000. How do I check for a bad hpop
Old 05-23-2012, 06:58 PM
CSP Resident Spooby
I've personally never dealt with HPOP issues, but my guess would be to get ahold of a QUALITY scanner, or something like AE that can monitor HPOP pressure while cranking.
Old 05-23-2012, 07:00 PM
I also had no codes when the the truck stalled stalled out
Old 05-23-2012, 07:09 PM
Well I think ill throw the the glow plugs and harnesses in tomorrow see if it starts and then take a look at the hpop. I also had a friend lose his hpop on his way to a fishing trip we had last weekend.he has a 2002 f350
