BB trick - Ford Powerstroke Diesel Forum
Old 05-15-2012, 06:10 PM
BB trick
I have been looking and searching on here for a couple of hours and I can’t find it. Can someone please tell me about the bb trick? I have a 97 CC 4X4 auto with 4:11s. I also have a 95 SC 4X4 auto with 4:11s. The 97 don’t seem to have half of the power the 95 does. I checked for exhaust leaks and see just a little soot on the up pipe connector. Hardly anything. The fuel pressure is 40 at idle and 25-30 at wot. The needle on the Fuel pressure gauge also fluctuates like crazy. I am going to replace the fuel pump this week and remove and reseal the fuel bowl and regulator. If someone can tell me about the bb trick before I take it all apart that would be great. Thanks.
Old 05-16-2012, 08:06 AM
bb trick?!
Old 05-16-2012, 11:34 AM
There is a bb in the fp regulator and from what I understand it could mess up fuel pressure or something like that.
Old 05-17-2012, 07:31 AM
Are you talking about shimming the fpr? Repost this in either the General Discussion area or the Performance area... this part of the forum doesn't get much attention.
Old 05-17-2012, 11:07 AM
Get the correct spring from International, and u also need a Fuel pressure tester, cant be over 70-75lbs.
Old 05-17-2012, 01:39 PM
Thanks, I will repost in general.
Old 05-17-2012, 02:53 PM
See my answer to your repost. Cheers!
