Help, can't keep it running - Ford Powerstroke Diesel Forum
Old 05-11-2012, 12:59 AM
Just put injectors and 17* pump on, ran great first 25 miles and now it throws the "injector control pressure above/below desired"and won't keep running when coming to a stop. I've replaced the ipr wiring and icp sensor...need fixed asap...any ideas?
Old 05-11-2012, 03:14 AM
May be a dumb question but is the truck tuned for the new hpop and injectors?
Old 05-11-2012, 03:17 AM
Stage 1 injectors and just a stock 17° pump...shouldn't need tuned, at least Jody said it didn't
Old 05-11-2012, 03:23 AM
Well i'm not gonna argue with a tuner!!! Lol
I didnt realize you could run bigger injectors and a different degree pump on a stock tune.
Old 05-11-2012, 03:26 AM
Yeah, should just run like a stock tune...but mine won't
Old 05-11-2012, 03:31 AM
Any way to check hpo pressure?
was the pump any good???
Old 05-11-2012, 03:33 AM
That's what I'm afraid of, but I don't have any way to check it
Old 05-11-2012, 03:38 AM
Ok, im not the best guy to explain this cause im not sure but what do you need to plumb a guage into the hpop circuit? I dont know if you need an adapter or not to get to a 1/4 npt.
I bought a hydrolic pressure gauge that went to 5000 psi for about 50 bucks from a local hardware store. That is how i would check it, but i have never tried to plumb it in.
Also, i work mids and am headed to bed man. Hope someone else can lend you better info!
Me personally, i would try to verify the hpo pressure somehow before anything else.
Later!
Old 05-11-2012, 03:39 AM
Thanks for the help
Old 05-11-2012, 03:41 AM
Yeah i dont think it was much though! Haha
Just thought, can you put a tee between the icp and head?
