What i am missing to get STARTED! - Ford Powerstroke Diesel Forum
post #1 of 8 Old 05-05-2012, 06:27 AM Thread Starter
Check list:
Change glow plus
Gas filter
i have oil fill
What is it am missing for my truck to start? Plus am getting white smoke!
islandpower is offline
post #2 of 8 Old 05-05-2012, 07:06 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
When your cranking on it, does the tach move at all?
Are you getting a wait to start light?
Check fuse #22 under the hood.
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #3 of 8 Old 05-05-2012, 12:17 PM Thread Starter
Fuse good ,getting signal from inside . i had the heads off, could it be the fuel lines need to bleed?
post #4 of 8 Old 05-08-2012, 06:53 AM
yes crack the lines between the fuel bowl and the head. crank it over and it will push the air out. it should start.
TOW RIG is offline
post #5 of 8 Old 05-09-2012, 04:40 AM Thread Starter
i crack the lines between the pump and the heads , and still nothing
post #6 of 8 Old 05-09-2012, 10:06 PM
Quoted: 84 Post(s)
Is your GPR good? Is the HPOP filled? how much cranking have you done? Did you prefill fuel bowl?
White95f250 is offline
post #7 of 8 Old 05-11-2012, 12:58 PM Thread Starter
Did all 3!
post #8 of 8 Old 05-14-2012, 10:15 PM
backwoodsboy's Avatar
Does the tach jump read while you are cranking it?
No start issue always make me think CPS.
Chrome don't get ya home
backwoodsboy is offline
