97 Low pressure oil pump failure ? - Ford Powerstroke Diesel Forum
post #1 of 1 Old 05-01-2012, 03:05 PM Thread Starter
Ray Bennett's Avatar
When the low oil pressure pump goes, does it normaly damage other componets, Ex high HPOP or injectors,or cylinders? How long do they normaly last, this one had 240k miles on it, Is that a normal to let go, I have not heard much on this type of failure and wonder if it may have been caused by somthing else failing. Right now the truck will not start So Im wondereing how much this mess could cost. Thanks.
Just bought!, 1997 F350 CCLB 5 speed manual, For now the only mod is the 4" straight pipe
2002 extended cab long bed 7.3, 3.5" lift with 37x 12.50 Terra Grapplers on 17" Pro Comps, ts 6 pos chip, 05 grille, DIY 6637 air intake, 4" MBRP exhaust with muffler delete, Built trans with PI TC tugger shift kit and suncoast 5 disk drum, custom made one peice drive shaft, Edge CTS
Ray Bennett is offline
