White Smoke
Hey everyone! Over the past couple days my '95 F250 has been subtly blowing white smoke at start and whenever I drive it and get the turbo to spool it smokes white and black lightly. I haven't changed the oil in about 3,800 miles, could this be the problem? I was thinking about fuel filter as well, which I could change. a buddy of mine said it could possibly be water in the fuel, which I don't know how that could have happened. Any suggestions or ideas are greatly appreciated. Thank you!
-Charlie |
low fuel pressure can cause white /greyish smoke , if it is time for s service , do that first , oil change and fuel filter and see if that makes a difference first
Ya I am probably going to change the filters tonight and I'll see if that helps. Thank you! How would I go about fixing the fuel pressure if it's too low/high?
well if its the fuel filter clogged ,then changing it may make it better , if not you may have a fuel pump getting weak
I forgot to mention, after my truck has been warmed up for a while, the white smoke will go away and there will be no signs of it.
have you checked your glow plugs,it could be that also being you said the smoke goes away after it warms up
