couple major issues.
First major issue is oil in the antifreeze fill tank. and anti freeze is leaking around the block heater/oil filter area, is there a gasket there that could be bad? its not coming from the head.
problem number two. Ive replaced the icp sensor and cam sensor but truck still does it, idles fine but when driving it will keep cutting out or stalling at random times. no lights or codes come up.
the first issue sounds like you need to put new seals and gaskets on your oil cooler. its a pretty common thing and i have no idea on the second one
thanks, crawled under and found where antifreeze was leaking around the back side of the cooler.
| Tags |
| antifreeze, oil, stalling |
