Truck is dead - Ford Powerstroke Diesel Forum
Old 04-13-2012, 04:30 PM
Truck is dead
So driving and truck died won't restart cranks like a champ though. Replaced fuse 22 removed fuel bowl heater repleaced cps. I'm getting 600 Psi from hpop. Fuel is good too. I read somewhere if you remove valve covers that you could see injectors squirting oil if working properly but no squirt. What next btw no smoke on crank and block heaters been plugged in awhile and its been in the 60s-70s here
Thanks
Old 04-13-2012, 10:52 PM
Is there fuel in the bowl? Does the tach move when cranking? Was the fuse actually blown? don't just replace it, actually disconnect the heater so it won't blow again. Check your wiring everywhere including the valve cover gaskets and under valve cover harness. Sometimes wiggling something will get it to act right.
Old 04-13-2012, 11:52 PM
Does the wait to start light come on?
Old 04-14-2012, 12:07 AM
and does your hpop resivoir have oil in it? if not fill it to aboit an inch from the top anad give her a ago
Old 04-14-2012, 01:30 PM
Wts light does come on no cel. Removed fuel heater. Tach moves when cranks and hpop resivoir is full. All wires look fine took off valve covers and all checks out good under there
