flickering wait to start
I have a wierd problem my truck 1995 2 wheel dualy 7.3 powerstroke 135k it just shut of going down the road pulled over shut it off tryed to start the wait to start light just flickered never fully lighting wait for a tow from friend when he got there about 20 min tried again start just fine went a few days did same thing so I replaced the cps and ran good for about a week several hundred miles sat for 2 days went out to start and the wait to start light just flickered never fully lighting checked all fuses all good checked codes none any help I need my truck I pull a big heavy trailer
I'd have the charging system checked. Also have the batteries checked independent from one another (cables disconnected from both). Also make sure your battery cables (all ends) are clean and tight. Additionally, you may want to look at the fuel heater element inside the fuel bowl and make sure that the element is still attached to the pads on the plate. If the fuel heater is shorting, it will usually blow underhood fuse #22, but not always. If the element is loose, disconnect the element from inside the fuel bowl and see if the problem goes away. Cheers!
I have replace both batteries and had the alternater checked, checked the grounds and all looks good I will check the fuel heater
Cam sensor
