oil pan removal - Ford Powerstroke Diesel Forum
Old 04-04-2012, 03:52 PM
oil pan removal
anyone replaced an oil pan in frame? is it best to yank the trans or lift the engine some to sneak it out? and is there anything else i might as well do while I'm down there
Old 04-04-2012, 04:44 PM
im no expert here from what i have read and heard you have to pull the motor out to get the pan off
completely out?
Old 04-04-2012, 05:40 PM
Never done it myself, but from what I have read for it to seal properly there can be no oil contact with the rtv that seals the pan to the block for like 24 hrs. To be done correctly I believe the block has to be flipped upside down.
Old 04-04-2012, 06:33 PM
Loosen the motor mounts, jack the engine up a little, swear at it a little, and take it out. It can be done, just need to have a little patience and be flexable. Once out, make sure to clean all old gasket material from block and clean surface with brake cleaner.
Old 04-05-2012, 02:05 AM
is there a gasket kit from ford or just some black rtv? and can i leave the trans attached?
Old 04-05-2012, 03:15 AM
if it were me and i had the place to do it id pull the, otor. only way to do it 100% right.
Old 04-08-2012, 12:11 AM
Pull it all the way out once and do it right once.
Old 04-17-2012, 09:22 AM
I just pulled my engine for a cracked front cover. cleaning all the rtv off the oilpan was a JOB. I couldnt imagine doing it in the truck. On reinstilation I put a nice gouge in the pan also!!! theres a bolt sticking out of the crossmember that the oilpan hits. such a fun job!!
Old 05-03-2012, 04:39 AM
on top of that, the oil pan still leaks!!!
I dont know of anything I could have done differently.
I even bought the big tube of ultra black for the caulking gun!
I was spackling that ****
all surfaces were beyond clean, maybe I should have bought a gasket?
that seems unheard of from what ive read
