Motor Hydro Locking - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-01-2012, 07:06 PM Thread Starter
Motor Hydro Locking
Need help took my 7.3 diesel on a trip. After we stayed at a hotel we came out and it was locked up. after some time we got it to turn over and startup. Left it run all the way home. Took about 2/3 a gallon of antifreese on the way home to. oil in the coolant. Went to work on and took the heads of and had them plained and put new copper sleeves in for the injectors. got it all back together and running and still have the same problem. Only does it when the truck has been good and warmed up and let sit for a little while. Crank is between 8 and 11 o-clock when it does this. Looking for suggestions of what else it could be and what pistons to look at when its locked up if someone knows the timing.
bucherav is offline
post #2 of 3 Old 04-07-2012, 08:56 AM
Maybe a crack in the cylinder of the block? If it's still eating coolant or maybe a crack in the head?
Turbo_pace is offline
post #3 of 3 Old 04-08-2012, 09:58 PM
Quoted: 48 Post(s)
Cavitation? Have you tested the coolant for SCA?
madpogue is offline
