Replaced fuel filter sensor now it won't start
I have a '94 power stroke, the fuel filter sensor was leaking so I unhooked all the hoses to include the fittings on the FPR and pulled the filter bowl and replaced the fuel filter sensor and put it back together. I filled the filter bowl up with fuel and now it won't start. I checked the fuses #4 25 amp fuse is blown, I replaced it and it still won't start. I don't have a manual so I don't know what #4 fuse is for. Any help would be appreciated.
I bet the fuse blew again.
Unplug the fuel bowl heater, then replace the fuse, then you'll be good. |
Thanks for the reply, I thought I read that the #22 fuse is for the fuel heater, the one that is blown is #4, unfortunately I don't have a manual so i don't know what it's for. I pulled everything back apart to make sure that I did everything right and when I get it back together I will try to unplug the fuel heater.
Idr which one it could be.
When you turn key on, do you get the WTS light? |
Yes the WTS light is on when I turn the key.
#4 would be for the power to the trailer marker lamps relay and trailer backup lamps relay (which shouldn't affect engine starting). Cheers!
Ok, thanks for the info, still can't get it to run.
Idk what I was thinking. You probably have air in the system. Just have to crank it out.
Get any smoke or anything when cranking? |
Thanks for the info, will it just crank the air out or is there a way to bleed it?
