truck shut off need help - Ford Powerstroke Diesel Forum
Old 03-21-2012, 06:10 PM
My 96 just shut off cruising down the road with no warning. The ABS light has been on for the past couple weeks on and off. I checked the codes, had a cps code and a icp code. I put a new cps and 2 different icps in and nothing, I even tried it with the icp unhooked. Then I found a burnt injector harness, it is burnt out side the valvecover in the main harness. How do you get this connector apart and are there parts available to fix it? It still wouldn't start with that plug unplugged and the gp wire pulled out of the plug, any ideas on what else might be going on?
Old 03-21-2012, 06:24 PM
If it's burnt, that's the problem. That supplies power to the injectors to fire them.
You need to check all the UVCHs and connections and replace as needed.
Old 03-21-2012, 06:47 PM
the baconator
they sell pigtail kits for that reason, also check the valve cover gaskets and teh UVCH
Old 03-21-2012, 08:00 PM
Always start with the basics:
* WTS light on?
* Does the tach move?
* Any white smoke?
Did you check fuses? Whatever boined up that harness might've blown a fuse in the process.
Old 03-22-2012, 04:31 AM
WTS is on, the tach comes up to maybe 200 rpm and doesn't move while cranking, no smoke. I looked over the fuses under the hood and didn't see anything, any of them in particular to double check? anybody have a part number for the pigtail kit? Can you get it anywhere other then ford?
Old 03-22-2012, 06:07 AM
Yea a lot of ppl sell them. Riffraff might.
My Samsung SGH-I997 made me send this.
Old 03-22-2012, 10:38 AM
How do you install the new pigtail, butt connectors?
Old 03-22-2012, 11:12 AM
the baconator
international will have them too
Old 03-24-2012, 08:46 AM
I now have found 2 burnt harnesses, is that just a coincidence or is there something else going on?
Old 03-24-2012, 07:31 PM
i had all 4 harnesses burn in mine due to bad glow plugs. replace the plugs , glow plugs and valve cover harnesses and all will be good. when i did that it solved all kinds of issues.
