95 running rough - Ford Powerstroke Diesel Forum
Old 03-10-2012, 03:01 PM
95 running rough
Ok, I had a no start, changed cps, and fuel pump was leaking from weep hole, changed it out, bled as much as i could, got it running idled fine about 20 min took it for a 15 mile run ran good until was aprox 2 miles from home started running rough then pulled in drive way it died, Will start and run on wd-40 but dies as soon as you quit spraying, not sure were to look now, thought about the filter in the tank but has two tanks and doesnt matter wich tank im on still same result, any help will be apreciated
