95 PSD wont start when hot
working on a 95 psd 4x4 dually auto. so my brother pulled into the gas station to fill up. filled the truck up and when he went to leave it would not start. had it towed to our shop to work on it. that same day we changed the fuel filter after the fact and still wouldnt start. let it sit over night and the next morning it fired right up. got it warmed up and shut it off and wouldnt start again. ordered seals for the ipr and bought a new cps. the next morning with motor cold i put the new cps in and changed the seals on the ipr. fired it up and my brother took it for a spin and it died on him on the drive. we've check all fuses and unpluged the fuel bowl heater. what else could possibly be bad on it? were do we go from here? any help would be appreciated.
also when it died on the drive , it didnt shrug or anything , i basically came up to a stop sign and it just died as if the key was shut off.
Somebody else had this problem and I went completely blank on what it was.....It's an electrical problem. Damnit i'll think of it in a bit.
I also must say that like a week or 2 before this happened , i was having this weird starting issue when it was hot , it would take a few extra seconds to fire up , when cold it did no problem |
I'm trying to remember if it was a valve cover gasket or not that was causing the short. One member here would be driving down the road and the truck would cut right off. Turned out to be a bare wire. Double check all your connections and wiring.
update im still having issues , but seems the problem escalated , so after i replaced the ipr o rings , and cps , it started up and ran took around the block coupld times it then died on me as i coming to a stop sign , it was as if someone shut the key off, so we towed it back to shop let it sit overnight went back in next morning tried to start cold and wouldnt start cold now. So now im not able to fire her up at all. I have replace the fuel pressure Screen (old one was brittle and clogged)
What could my problem be now? |
Check valve cover gaskets and UVCH for burnt wiring and shorts.
Have you tried the water bath method like on them old IDI's?
Next time it doesnt start when hot, if you can try shooting some water on the Injection Pump (the IDI IP #5013 was good at not starting when hot). If it starts, then you have your culprit. |
I'd swap out a the IPR and try that. That was the problem on mine.
No start hot, dying hot, etc. are usually high pressure oil issues, since the oil gets too thin at those temps. Might be ICP or IPR. Last oil change was when? |
