95 7.3 heeeelp
Engine cranked up this morn no problem, went to crank after work fired up on the third long crank , never done that before, on the way home died when i would shift gears, got it home ran 10 min or so at idel no problem , i shut it off will not crank anymore, changed fuel filter, changed oil (it was due), and air filter, checked batteries, have good pressure out of hpop,and out of fuel bowl, I was thinking cps? what do you guys think
Not too much info to go on... You have fuel and HPOP pressures, so you need injection...
Check fuse #22. Shorted fuel bowel heater will kill the engine as it supplies power to the PCM and maybe the IDM???? Bad CPS can mimic your engine symptoms. Its probably the easiest sender to change and fairly inexpensive. Best to get from Ford or Navistar dealer. But if your stuck, get one from nearest auto-parts store. Electrically, all 7.3's the same from 1994.5 to 2003. So application year does not matter. Think the changes are limited to tin or gold contacts. (This is not the time to try CPS from different engines DT466E etc) Last edited by roddy; 03-08-2012 at 05:02 PM. |
