blue smoke at idle, oil in coolant and i think coolant in oil?? - Ford Powerstroke Diesel Forum
Old 03-02-2012, 01:46 PM
ok i have a 97 7.3 truck runs great. at idle it has blue smoke from tail pipe and it burns your eyes. when i took the valve cover off to replace the injector harness and valve cover gasket there was gray sluge on the inside of the valve cover but the head area looks perfect. and the is a film or thick oil in my coolant bottle.... am i screwed?? please help.
Old 03-02-2012, 02:08 PM
if its coolant, it's probable coming from your oil cooler, or injector cups.
Old 03-02-2012, 03:15 PM
could be condinsation build up on the VC from cold starts and driving around and shutting it off before it has time to get up to temp.
Old 03-02-2012, 04:18 PM
if he has oil in the coolant overflow, id say oil cooler is where id start. condensation wont cause oil in the overfolw tank.
Old 03-02-2012, 05:44 PM
ill start there, thanks for the replys
Old 03-05-2012, 07:35 AM
hope this helps, this might be whats going on
