icp codes help - Ford Powerstroke Diesel Forum
Old 03-01-2012, 05:50 AM
icp codes help
My 97 f350 has a p1212 and p0340 coming back as soon ad I start the truck. I have icp pressure and rpm when cranking. The Icp is around 850 at idle and icp is 15% the cps is new and the icp doesn't look too old but I'm not sure. Help please! Truck runs ne but cel is on!
Old 03-01-2012, 06:58 AM
Full A-Team Member
Pull the plug on the icp, is there oil in the plug? if so the icp is shot. Also check the wiring by the icp. Something is definately going on with it.
Old 03-01-2012, 07:00 AM
Full A-Team Member
Also the other code is for the CPS, might want to change that out also.
Other than the CEL what is the truck doing...I assume runs like crap with less power than normal, or does it even run?
Old 03-01-2012, 07:09 AM
The previous owner said the icp was replaced but It does Have some oil in the plug. Could be from the old one. As for the cps I replaced It yesterday amf the code still comes back. The truck runs fine. Starts right up doesn't die. Sometimes the idle hunts a bit?
Old 03-01-2012, 07:13 AM
Full A-Team Member
The idle is comming from the ICP issue. What are you clearing the codes with, when they are cleared it throws a CEL right away on startup?
Also try wiggling the ICP plug around so it makes good contact.
Could be a possibility of the ICP plug being bad
Old 03-01-2012, 07:20 AM
I'm clearing it with am oasis scanner and they come back as soon as I start the truck. I think they came up when I did a koeo self test too I don't remember. And what about the cam code and what about the ipr causing problems I'm kinda lost here.
Old 03-01-2012, 03:27 PM
This thing is so hacked I think I might get rid of It
Old 03-01-2012, 08:13 PM
Full A-Team Member
ouch........
Old 03-02-2012, 04:36 AM
Well can anyone help me diagnose this at all.
Old 03-02-2012, 08:29 AM
help
If you are at 15% duty on the injection control pressure you have a bad hpop.
