Intercooler installed, somethings not right?
Hey guys so a couple weeks ago I installed the banks techni cooler kit on my 97 psd 5spd and it feels like something is not right. If I stomp on it in second and continue full throttle through the gears until fourth it feels like its sputtering. After putting the intercooler on my boost has gone from about 23 to around 16 and just feels kinda like a turd. Now with that being said on the free way doing 70 and flooring it, the truck gets up and goes WAY faster than before it was intercooled so I have noticed the unit did help significantly on the free way. Now while installing the intercooler I did cut through the main ground from one battery to the block would this affect performance in any way? It still starts up fine and I have no known electrical issues, I have a new cable but have had no time to replace it. Any knowledge or two sense would be greatly appreciated thanks!
Adding an intercooler will increase the air volume your turbo has to fill before any noticeable boost can be made. You are experiencing increased turbo lag. The reason you don't notice it on the interstate as you have mentioned, is because the turbo is already spooled and your air charge is relatively cool with all the air moving over the intercooler. Step up to a smaller ratio compressor housing to return to or improve upon your factory turbo response.
I know turbo lag and it would be increased but only a very little bit...maybe half a second tops? Seems like the op might have something else going on. To the OP, it is typical to lose a little boost with an intercooler. When you cool something that is under pressure, it will lose a little bit of that pressure. I don't think 7 psi is good though. A decend ic will usually drop the boost by 1 or 2 psi. Might have a boost leak at one of the new connectors? I would fix that cable. Might not be your problem, but you are over straining the bat that is still hooked up. Hope i dont piss anyone off!!! Trying to do this respectably. |
Just read this
White/grey smoke at full throttle? This is you too right? Might have something to do with what you have going on in this thread... |
Hopefully but keep us posted.
Oh and CHANGE that bat cable!!!! Lol |
On the other hand though im kinda thinking now I probably dont have a boost leak because at highway speeds(65mph+) it gets it pretty dang good and feels as if its running proper. But hey who knows maybe I only think it is running proper because maybe I do have a boost leak and just haven't experienced the inter cooler properly yet.
That kinda sounds more like a fuel delivery problem (frp screen) to me.
short high throttle runs wont drain the fuel bowl but longer runs like 2nd through 4th will demand more fuel longer which could show a delivery problem. this is only guessing though because a fuel problem normally would have existed before the intercooler install. how long has the ic been on??? Dont remember if you happened to say. |
i might not be any help but to me it sounds like a fuel problem. when you are at WOT on the highway is the boost staying steady psi?
