need help before I get robbed
last week while driving down the road to get fuel my 1996 f250 7.3 turbo diesel truck all of a sudden started running rough and lost almost all power,limped it back home barely running changed fuel filter no change,took it to mechanic who said it was injector harness,so now week later he installs it,same issue says he ran buzz test now he says idm must be bad and that I would have had to change harness anyway because it was what probaly made idm go bad.He had a genesis scan tool,I'm begginning to believe he is out of his element will the injectors buzz with a bad idm and do both these parts go bad at same time,I'm not a rich man and can't afford to trial and error,personally I don't think he should have changed something without finding out for sure if it was bad any ideas on what this problem could be,truck will crank just acts like it is running on 4 cylinders no power at all.thanks in advance for any help,it will be greatly appreciated.
very well could be the idm
On my '01 a UVCH went out (shorted under the cover) and took the IDM with it.
thanks guys,I'm new to working on diesels,would a bad uvch be obvious when looking at it.Don't get me wrong I'm not saying the guy is a crook he seems nice enough,just not sure if he is a diesel mechanic or bit off more than he could handle.trial and error can get expensive.
Unplug one side of the uvch and then the other side and see if anything happens. How low on fuel were you when all this happened? It would suck if you just had air in the lines.....but anyways does he know what to listen or check for during the buzz test? These things have wires that short out all the time so just bare with us on diagnosis. Wiggle things around and give everything a very close visual inspection.
I unplugged one plug on passenger side and nothing changed thats when he said it was injector harness so he changed it today,wasn't there when he did buzz test will find out tommorrow about it,one tank was really low but I had already switched to other tank which had several gallons in it and driven about 10 miles, when this happened I was on my way to fuel up which I went ahead and did because I thought it was running out of fuel,How can I tell if it has air in lines,that would suck after spending all this money but it would also be a relief not to spend anymore and a lesson learned.
ty for all the help guys,turns out it was a bad IDM,I know now they quit without warning lol.Just out of curiosity truck would run just on 4 cylinders,I changed the cam sensor 3 times yesterday before I got a new IDM with cam sensors from advance,o'reilly,and napa truck would not fire period each time I put the old one back in,It would start no one can seem to explain this not even the mechanics I talked too,I've read allways keep one handy but my truck don't seem to like new ones,thanks again for the help.
