help help help - Ford Powerstroke Diesel Forum
Old 02-10-2012, 02:47 AM
help help help
Anyone know where I can get the gasket that u put on the compressor manifold to turbo. It's where the small black y pipe connects the heads to the turbo. All you do is tighten hoseclamps to install the manifold. The gasket is round and flat. Thanks
Old 02-10-2012, 04:53 AM
I got mine through either NAPA or Ford, but as I recall it was part of the upper gasket set not by itself. Let me dig around and see if I can find it by itself somewhere.
EDIT:
Are you talking about #9E436 (7.3L; DI Turbo; Seal-Turbo compressor outlet(mounts between 6K682 & 6K889))? It is $5.54 at fordparts.com. If you go to FordParts.com, either put in your VIN number or your vehicle year/make/model. That'll take you to the catalog. Select Engine under Category, which will pop up a question about which engine you want. Select the 7.3 V8. Under Sub-category, select Gaskets and Sealing Systems. I found it on page two, titled "Intake Manifold Cover Gasket".
Old 02-10-2012, 11:58 AM
Here ya go:
Turbo Compressor Outlet to Y-Pipe O-Ring (94-early 99)
(Ford) F4TZ-9E436-A
(International) 1818372C1
Cheers!
