Witch part is bad?
Ok when I first start truck cel is on the truck runs ok but has a loss of power then after 10 min of running the cel will go of and truck will run like poop, skip spudder and die some time. Iv tracked down to eathere the ipr or the icp
Bc when I unplug the icp the cel stays on and truck runns in the default presser but what 1 do I replace ? I'm guesing icp bc there was oil in the plug.Any input would be assume thanks |
ICP...........
you have any way to pull the codes from the CEL? that will tell you if the ICP is the culprit. Also is there oil in the ICP plug?
EDIT, nevermind, just saw that you have oil in the plug, the ICP is shot. When you replace it you need to get the codes cleared, it may not function correctly until you do. |
Thanks, ok ill give the icp a go. At least
its cheaper than the ipr i think. |
btw thats a nice, clean obs for 450,000 :-)
Thank you.
Yeah the ICP should be cheaper than the IPR, check Ebay, should be $30-70 on there |
