HPOP suggestions?
I have a 97 F-350 powerstroke cc lb, the other day the bearings in the hpop exploded, i was looking for new pumps and found them for around $500. but i was also reading on some forums that it is better to run a 17* pump off a superduty. I was wondering if that is true and if so then is there any thing that i would need to do to make it work.
Thanks. |
17* superduty pumps work well with your truck. but for a little more than 500, you can step into a adrenalin pump from sinister diesel.(at least i beleive thats what they are called now) it works well for almost anyhting the normal person could throw at their truck. I ahve it on mine and see a constant 3500+ psi. good product.
and another question, will my IPR work on the superduty hpop, if so should i use my old one or buy the superduty hpop and ipr combo for like eighty dollars more.
For less than 500, you can get basically the same thing as the adrenaline from terminator engineering.
thanks for the info, do you think i should get a new ipr, the one on there has 270,000 miles on it.
If you feel you must. Get a new one and keep the old one for a spare.
If there is no damage to the IPR from the HPOP failure, there is no need for a new one. |
Pull the plug on the IPR if there is oil in it, replace it.
