7.3 engine vibration - Ford Powerstroke Diesel Forum
Old 01-27-2012, 10:07 AM
97 7.3 370000.miles oil changed 500 mi ago. has engine vibration that is getting worse. always present but more at 1800 rpm. just started vibration about 2000 mi ago. runs fine . no loss of power. no smoke. I fear a main bearing or something. any ideas. please help, cannot afford a disaster now
Old 01-27-2012, 10:09 AM
do u kno what kind of clutch you have??
if you have the dual mass flywheel clutch setup, that's what id say it is.
Old 01-27-2012, 10:26 AM
I put in a LUK solid clutch at 200000 mi. Replaced the clutch throw out bearing 15000 mi ago. Clutch in good shape after new bearing. Engine vibe present with clutch in or out.
Old 01-28-2012, 09:08 AM
check your engine mounts and the transmission crossmember and mounts
