Leaking fuel like its her job - Ford Powerstroke Diesel Forum
Old 01-20-2012, 01:21 PM
Ok so when I went and looked at the truck didn't leak anything. I drove it two hours home and it started leaking fuel, its dripping down the pass side of the trans. And does have fuel in the valley, is it the icp sensor, or injectors I'm stumped
Sent from my C771 using AutoGuide.Com Free
Old 01-20-2012, 01:38 PM
ICP is for HPO.
Clean it, and check all the fuel lines that like to fall apart around the pump, make sure the pump isn't leaking, check the filter and make sure it's seated.
You just gotta find it.
Old 01-23-2012, 07:53 PM
Mine does the same damn thing....the circled sensor in the the pic, is that ICP??? It was pretty wet. You can see the puddle of fuel in there too. Plan on replacing all those hoses too.
Old 01-23-2012, 08:40 PM
Full A-Team Member
The ICP has nothing to do with fuel and is located on the driver side head in the front. The circled one is the water in fuel sensor I believe.
On the fuel leak, it is either one of the 3 short fuel lines on the fuel bowl(in pic above) are the most common, and just the fuel bowl itself is prone to leaks, they make complete o-ring kits to rebuild them
Old 01-24-2012, 12:17 PM
I believe I have it fixed it was a 40 dollar sensor can't remember Fords long name for it
Sent from my C771 using Tapatalk
Old 01-24-2012, 02:22 PM
Was the sensor leaking or just the oring?
Old 01-25-2012, 02:29 AM
Sensor, right through the pig tail side
Old 01-25-2012, 04:17 AM
Hmmm, that's a new one. Usually it's just the oring. Well glad ya got it.
Old 01-25-2012, 10:45 AM
Do you have a part number for it???
Old 01-25-2012, 12:20 PM
If I can find the package it was in I do
