HPOP res. Leaking down. - Ford Powerstroke Diesel Forum
Old 01-14-2012, 04:01 PM
I have a 97 f250 and the HPOP Res keeps leaking down. It will not star untill you add oil through the check plug. i have done the injector o-rings in the last 5k miles. it has 175k miles it has had a new front cover and i guess a couple LPOP's prior to my purchase. Where do i start? is there a bad injector, HPOP, the LPOP not correctly set? how can i test it before i just throw parts?? Please help i dont want to go to the dealer! lol
Old 01-14-2012, 04:26 PM
I know that the older ones had anti drain back valves that would go bad but idk about a 97
Old 01-14-2012, 04:37 PM
Is there a way to test that or just replace???
Old 01-14-2012, 04:45 PM
One way to Ck injectors is to remove valve covers. clean the oil deflectors with brake cleaner or something else. then put a rag or a piece of paper under the deflectors and let it set to see if it leaks oil. If it leaks replace that injector.
Sent from my MB860 using AutoGuide.Com Free
Old 01-14-2012, 05:20 PM
ok perfect! how long are we talking to let it set? And you are talking about it leaking out of that pin whole on the injector? correct?
Old 01-14-2012, 05:33 PM
If you pull the injectors for any reason you have to replace the o-ring no matter what??? And I didnt torgue the injectors when i installed them after i replace the o-rings. Should i pull them to see it any of the o-ring get to any excessive heat due to improper seating before i do anything else or will seeing if the injector leakes under the deflector tell me if the o-rings are bad???
Old 01-14-2012, 05:35 PM
Could very well be the gasket between hpop and cover
Old 01-14-2012, 05:41 PM
how would i ever see if it is that gasket between the cover?? Also i was getting like 18MPG AVG when i bought the truck and then after a while i started getting 13-14MPG. IDK if that helps at all?
Old 01-14-2012, 06:01 PM
Let it set over night or so. The deflector I am talking about is the alum. Piece on the valley side of the injector that is held on by allen head bolt.
Old 01-14-2012, 06:04 PM
perfect thanks alot. ill see what happends.
