Oil pick up - Ford Powerstroke Diesel Forum
Old 01-04-2012, 12:00 PM
Oil pick up
ok here is my issue: My oil cooler was leaking real bad here as the weather is getting colder so I decided to replace the O rings. That was the easy part. While putting the cooler back on (or taking it off) we broke the bottom mounting bolt off the front cover. I started to tear everything apart and now is sitting. I ordered a used cover from a bone yard and everything matched up over the phone. I get it yesterday and noticed that the oil pick up tube mounts on the passenger side on the new cover. My truck it mounts on the drivers side. That is the only difference in the covers. I called Ford and got no help. I want to see if anyone knows if I can get an pick up tube that mounts on the other side. Any help would be great since the truck has been down a week and a half already!!
Old 01-04-2012, 06:07 PM
I think there is more to it than just changing the pickup. Here's is some more info that may help (you may need your engine serial number):
Front Cover
A deareation valve was inserted in the front cover beginning with engine serial number 201681 through engine serial number 375549.
The front cover was redesigned starting with engine serial number 375549 to help keep the oil pump primed for initial start up. To accommodate this change, the pump inlet port was rotated 90� which moved the pickup tube from the left to the right.
The front oil cooler header gasket was also redesigned because of the change to the front cover.
The front cover has been modified for the updated reservoir to front cover gasket and passages have been cast and drilled into the front cover to incorporate the standpipe.
The engine serial number that the standpipe was incorporated is 201681.
Oil Reservoir for the High Pressure Pump
As of engine serial number 187100 the reservoir has been cast and drilled to include the standpipe and is drilled, tapped, and spotfaced to use both a straight thread, o-ring sealed engine oil pressure sensor and inspection plug as sealing enhancements.
Oil Pan
Due to the relocation of the pickup tube the oil pan baffle was redesigned to allow the pickup tube to pass through it to the bottom of the pan. This was done as of engine serial number 375549.
High Pressure Oil Pump
The high pressure pump has had the drain check valve deleted. This brings the variation of high pressure pumps used on the DIT to three. The pumps may be identified by the absence or presence of the anti-drain check valve.
On 1994 1/2 and 1995 model year engines up to serial number 187099, the initial high pressure pump did have a drain check valve but did not have an edge filter. The edge filter was part of the injection pressure regulator.
On 1995 model year engines starting with serial number 187100, up to serial number 201680, the high pressure pump did have a drain check valve and an integral edge filter. The edge filter was deleted from the injection pressure regulator.
On 1996 model year engines starting with serial number 201681, the high pressure pump does not have a drain check valve but continues to have an integral edge filter.
High Pressure Pump Gasket
The high pressure pump gasket has been modified to seal the standpipe between the pump and front cover.
Note: The correct gasket must be used to prevent internal and external oil leaks.
Here's where the info came from: "7.3L DIT Anthology"
If you can find a version that has the pictures too, that would be helpful as well. Cheers!
