Hard shutdown?
hey guys my truck has always shook a bit when shutting it off since i have had it but it has seemed to get alot worse?
any ideas |
Stick shift? Could be your dual mass flywheel going bad
Auto, but I had my trans fluid and fliter changed and flushed and now my truck is making really loud vibrating and humming sounds around 35-45mph and 70-80mph , and just today when it down shifts it makes a sqeeking noise for a sec not sure if these issues are related though? Thanks for the quick reply
anything? where to start im lost, was told to replace cps, i did with no luck
The vibrating/humming at speed could be u-joints. Out of curiosity did you check those?
@ shut off....Have you looked at the motor mounts or trans mount? It's a suggestion. |
i took a look at motor mounts, seemed fine, Whats the best way to tell if my u joints are bad? i know probly a dumb question but i took a peek at them a couple weeks ago looked ok but i also dont really know what they look like brand new? im a neb haha
Grab ur drive shaft at the front where it comes out of the transmission and at the rear where it bolts to the rear axle grab just slightly behind u joints wiggle up and down and side to side u shouldn't have any play if they are in good condition if u feel or see any movement then that's deffinately where ur humm and vibration is coming from. Oh yea they will also squeak some times I would put money on worn u joints
