Fuel leak - Ford Powerstroke Diesel Forum
Old 12-19-2011, 06:35 PM
Fuel leak
Just bought this truck and has a issue. Whenever I drive it (normal temps) then park it a puddle form underneath the truck. The fuel is coming from the bell housing, right behind the motor. What can this be. Truck runs/drives fine there is just a leak when I park it. To be real technical, there is a metal dust shield that mounts to the bell housing. The fuel drips out of this area.
any suggestions guys?
Old 12-19-2011, 06:36 PM
Illiana Chapter Director
Either the fuel filter housing has an o-ring leaking or the fuel pump is leaking.
Old 12-19-2011, 06:39 PM
duct tape & zip ties
Fuel Filter housing is leaking. Or you have a loose or broken fuel line. I will look at the fuel filter housing. More specifically the fuel water drain. It has an o-ring that is known to go bad.
Old 12-19-2011, 06:42 PM
Are you following me?
Try this link Chiller.
Replacement O-rings for Ford Diesel Engines
Old 12-19-2011, 06:45 PM
No but you said fuel pump. The fuel is coming down from the bell housing. If you would have read the op fully you would have seen that.
I put money on the fuel filter housing leaking which is common. As I know you know this also.
Old 12-19-2011, 06:48 PM
I said pump because my 95 did that. I also said filter housing.
Old 12-19-2011, 07:12 PM
Where is this fuel filter housing located, topside back of motor? im new to these 7.3s
Thanks for the fast responses tho
Old 12-19-2011, 07:14 PM
Towards the front of the engine in the valley. Right underneath the black cover if yours is still there.
Old 12-19-2011, 07:15 PM
Ok thanks im gonna take a closer look at this see if i cant figure this out. Thanks!
Old 12-19-2011, 07:18 PM
No problem
