rough idle?? Help! - Ford Powerstroke Diesel Forum
Old 12-11-2011, 02:22 PM
rough idle?? Help!
I have a 97 7.3 Powerstroke i just bought in Oct. I noticed it was having trouble starting in colder weather so I decided to check my glow plugs. well I didnt have to get very far, I unplugged my 4 wiring harnesses on top of engine for the glowplugs/injectors and noticed the outer connections on 3 of 4 harnesses were burned up. so i ended up replacing glow plugs, relay, inner and outer connector harnesses and valve cover gaskets. I replaced everything but the outer harnesses (ran out of time) then I fired up the engine, it started running rough at that point. So then I finished a couple days later by wiring the outer harnesses, problem didnt go away. I thought an inner connector came loose, so to figure out which head it was coming from I unplugged each harness 1 at a time while running and the engine didnt change idle on the front driver side harness. so I pulled back off the valve cover and ohm tested all connections (everything checked ok). I did notice the 2 front injectors seem to not change idle when unpugged (both 1 at a time), and they make a clicking noise while plugged in I dont notice from rear 2 injectors that seem to work fine, then goes away when unplugged. If I unplug any of the other 3 harnesses the engine almost dies but not driver front. This is killing me cause all I did was make all the connections better. and yes I double checked to make sure I didnt cross any injector wires. any help would be greatly appreciated.
Old 12-11-2011, 05:28 PM
"update" the damn brand new internal wiring harness from the gasket to the injectors/glow plugs had the center wire on the gasket side not connected to 1 injector. hell of a deal! guess i'm gonna use the best of the old connector.
