94.5 runs but will not accelerate!
I have a 94.5 f350 that we swapped a 7.3 into. we have it running now but it wont accelerate and will only idle. the motor is a 94.5 the wiring is from a 95, underdash harness 95, pcm 95. We used a test light and there is no power to the throttle position sensor. the ivs was also jumped but no luck
I also have three large plugs that i cant figure out where they go. these are tied in to the underdash harness near the throttle pedal. i have looked at a 96 and a 97 and neither have these plugs. what are these for? thanks |
94.5 wont accelerate
I also have ford service manuals and the plugs are not listed
Got any pics of the plugs? Either that or a description (rectangular or circular, color, # of pins, number of wires, rows, wire colors, etc). Cheers!
plugs
there are three rectangle plugs. two are gray and one is black. i will post a picture of them in the morning
tps
i cant get the pictures of the plugs to load. I do not have any power to the throttle position sensor.
I dont remember exactly how the sensor works but do you have power across it when you press on the pedal?
when you press the throttle pedal, do you get a CEL? this happened to me, i had to unplug the plugs at the pedal and spray with electrical spray, havent had the problem again.
tps
I have no power to the tps plug but there is power to the ivs sensor. When i was using a test light on the tps, when i touched the plug it woulg trip the glow plug relay. I also have a check engine light
tps plug
Any ideas why there is no power to the throttle position sensor plug?
Check any fuses? under the hood and in the INterior?
