fuel pump installed and no start?? - Ford Powerstroke Diesel Forum
Old 11-14-2011, 12:55 PM
Just put a new lift pump on my 97big f250 and need info on how long it takes to prime this damn thing??
Old 11-17-2011, 04:10 PM
a while if you dont fill the bowl. Still, it takes a while. Take the filter off, and fill it with diesel, put the filter back in, and crank it a while. if it doesnt start, take the filter back out and look and see if theres air in the bowl. if there is, fill it back with diesel. Keep cranking (but never more then 15 seconds, letting it rest in between).
Old 11-17-2011, 09:59 PM
X2 fill the bowl and crank but let the starter rest and cool down in between cranks. To get the air out of the line let it run for a little bit and then give it a few good revs to force the air out.
Old 11-18-2011, 12:17 PM
With all the pump replacements I've done, I've never filled the bowl and the truck always started right up (like nothing had been changed or drained). If the truck was actually run out of fuel, that would be different. Also, make sure that the IPR wiring is connected to the IPR (this gets left off a lot) and that underhood fuse #22 is good. Cheers!
Old 11-18-2011, 12:38 PM
a friend of mine changed his fuel filter and let air in. it died and we had to do the above. He may have not done it correctly, you never know.
Tags
fuel pump, primeing
