Help! GPR Problem
ok i have been beating my head in for the passed day now over this , so heres the deal.
power on the constant post at all times,when the key is on the 2 smaller posts have power but i get NO power on the glow plug side. the relay is brand new and when i take it out n bench test it, it completes the circuit. when i remove all the wires and KEY ON the constant has power and only one of the smaller wires have power i believe it has n orange tracer on it. if i put that onto the solenoid on one post it will actually power the other small post too.....HELP i know its prob something dumb but im at my witts end. there is a good ground on the solenoid i even sanded the pedastal it sits on to make sure n tested it. |
Hey, I just posted an article that explains the wiring, function, and testing of your relay. read this and it will help you (and save me from typing the same info again)
![]() the title is "tis' the season...' |
Ok thank you I'll check it out
The base does NOT ground. If you have a relay that grounds through the base, it's the wrong type of relay, and it will run constantly.
