7.3 No whistle
Hey guys, this is my first post up on this forum but ive been watching for a while. You guys got so good help on here and better than allot of the other truck forums ive seen. I have a 1997 CC LB 7.3l 5 speed stick shift.The question i got is that i have absolutely no audible turbo whistle. Which at first sounds unharmful but i have a straight pipe exhaust and an intake and there is still no audible whistle. This leads me to beleive there is some underlying problems. Im not really sure how my power is compared to others but this lack of whislte on a straight pipe exhaust is kinda confusing for me. I guess it would be a good idea to see what kind of boost im pushin?
If there is no whistle then you turbo is not spinning because at idle you should be able to hear it at the tail pipe so the could be the problem
Where does your exhaust exit and how are you judging that there is no whistle? If somebody is revving the truck while you're outside of it and there is no audible whistle at the pipe then there's a problem. If it's just you then I would place a camera at the exhaust exit and record while you rev it and let us hear it.
its got straight pipe stacks and trust me there is no wistle anywhere in the rev range and any sort of load. The only thing remkinisent to whistle it does is when its in gear(5 speed manual) and its over around 2000rpm it will make a vacum like noise. Also it feels like the same power nomader how much throttle you use.
check the turbo... do u have a boost gauge?
no boost gauge but ill check the shaft play.
Are you blowing a lot of black smoke as well? Pull your intake off and look at your turbo wheel. And check all your IC pipe boots.
im not blowing any black smoke whatsoever but ill tell you that crankcase ventilator put damn near a ****-ton of oil in my whole intake system. the compressor whell is bent slightly on one blade but do you thing its possible for the exhaust side and the intake compressor to not be connected in that thered be no force to compress air? im going to hook up a boost gauge tonite after i hit advanced. Any other thoughts? by the way ive burnt through over 2 qts in 300 miles and found a oil in the valley and around my power steering driver. Thoughts?
Sounds like you have serious turbo problems. I would pop your down pipe off out of the way and inspect both sides of the turbo at the same time. Its rare BUT I have seen a turbo break its shaft and only half work (it was a turbo 2.3 gasser). How much blow by does your truck have? Will it blow the upside oil cap off pretty quick?
