help with start up - Ford Powerstroke Diesel Forum
Old 11-01-2011, 09:20 AM
Send a message via Skype™ to Gertrude
help with start up
ok guys have several questions,
1. when i start my truck for the first time of the day usually about 10am after sitting for all night, my truck is really hard to start and its only around 50* right now, it POURS out this white vapor/smoke cloud that smells like diesel, also my uvch has a wire that has come loose and easily pulls out of the plug, so i been told that could cause the problem and i wanted to make sure that could be the problem
2. my truck seems to shake really bad when i first take off from a light or stop sign, sorta like it has wheelhop, could that be some axlewrap?
3. sometimes the trans shifts weird like it has an extra gear or something, i know it sounds weird but it shifts pretty firm 5 times and i know our trans are only 4speeds with OD, and it shifts pretty early at like 30mph it will go into 4th i think, i'll drive it today to post up so more info on how it drives
4. after my truck runs for about 30 sec it cuts out really bad for a split second, and then maybe 10-15 sec later it will cut out again and most of the time will die, the wts light doesn't come on, but it will fire right back up and doesn't cut out again until i park it and shut it off again for about 5+ min, and then if i start it again, the process repeats, but the truck has to sit for at least 5 min for it to start acting up
5. another thing, my speedo acts crazy after about 40mph, it will jump to 70 and back to 40-70 and anywhere in b/w, so idk what is causing that, if that has to do with anything and what could cause that?
so some input would be greatly appreciated thanks!!
Old 11-01-2011, 11:24 AM
Oooh. SOn, This is a UVCH problem. CHeck all your connectors and plugs. Take off the VCs and look at the connectors that go in the VC gasket.
Old 11-01-2011, 11:31 AM
Interior Guru
Feedback Score: 3 reviews
Replace the uvch or plug. Wherever that loose wire is. That can cause a lot of issues. Also replace the glow plug relay. Or at the very least test it and verify your getting power thru it. If its not the same on both large posts with the key on whenever you first key on that is. Then its bad.
Old 11-01-2011, 11:36 AM
the plug is bad so i dont think i have to pull the vc off the damage is on the outside so hopefully the inside is fine
ok i'll pick up a new uvch and do the stancor mod, but ill test it first, pretty sure its bad
thanks guys
Old 11-01-2011, 11:42 AM
there are two of those right? one on the pass fender, and one on the engine? do i test them both?
Old 11-01-2011, 11:44 AM
One on the fender is the starter RElay.
Old 11-01-2011, 11:49 AM
Interior Guru
If that loose wire is in the plug going TO the uvch connector... you can buy a replacement plug. Check the uvch connector for damage though. And what Gabe said. The relay by the fuel bowl is the GPR
Old 11-01-2011, 11:52 AM
its more like the relay behind the alternator lol
Old 11-01-2011, 12:01 PM
Interior Guru
2. Sounds like a bad u-Joint or trans slippage almost. Not real sure.
3. The extra gear is the torque converter locking up in 2nd or 3rd
5. Clean the vss in the rear axle. It can cause transmission malfunction as well
oh ok then idk that you could just buy replacement plugs, it is more complicated to just replace the whole uvch
