IPR harness/fuel bowl
Trying to find a part # for the IPR harness. My harness is all chewed up and brittle.
Thanks,tw
Fuel Filter Housing Wiring Harness
(Ford) F4TZ-9S277-A, (International) 1825188C91 (94, early 95) (Ford) F6TZ-9S277-AA, (International) 1807333C91 (before 2/5/96) (Ford) F7TZ-9S277-AA, (International) 1825754C91 (from 2/5/96) Later ones will work on an early truck (early ones seem to be outrageously priced). Get it from someplace like Tousley Ford Parts (good prices on factory parts). Cheers! |
Thanks for the reply,mine is a 97 so i need the later harness unfourtunately because of the different IPR's on the older strokes. I even have a older harness but the plugs are different for the IPR.
Thanks agin, tw
Plug on the IPR shouldn't be any different configuration-wise (other than gold contacts). They are the same as the injector connectors. Cheers!
The plug on the IPR's themselfs are the same but the harness use different clips the older ones have two clips on the side and mine use a wire clip simialar to a cam sensor plug that hinges over the plug im sure it would work but im just anal. I just looked up the one for mine and its 60 bucks so im just going to get that one.
Thanks,tw
They did the same with the clips on the injectors too (the plastic ones would just break off). Cheers!
