Hpop? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 10-19-2011, 07:48 PM Thread Starter
Hpop?
I have a 97 f350 5spd crew cab, its was running rough around 2300 rpms and idling rough, one day it was warming up outside and i went out there to go to work and it was spraying oil out of the back of the hpop. i took the oil pump off and took it apart and all the bearings inside were shattered. so i was wondering if a hpop out of a 95 would work cause i had one and put it in there and i cannot get the truck to start now.
warrenbrunick is offline
post #2 of 7 Old 10-19-2011, 08:47 PM
atvrider93's Avatar
Quoted: 8 Post(s)
it should work. you just have to check other things. have enough oil? sure you connected everything right? I would be worried where those pieces of shattered bearing went
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #3 of 7 Old 10-19-2011, 10:57 PM
JSchuricht's Avatar
Depends on when the 95 was built. 94 and early 95 HPOPs are different. Also, double check the bolt on the front of the HPOP, I have been fooled twice by one that felt tight but ended up being loose keeping the truck from starting.
JSchuricht is offline
post #4 of 7 Old 10-19-2011, 11:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
96-03 hpop is interchangeable, 94.5-95 are a weird shape, something with the drain back Iirc, good luck tho.
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #5 of 7 Old 10-20-2011, 10:58 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
Get a rebuilt 17*..less than $500 all over Google, or get a good low mileage used one
CT Performance, Inc. is offline
post #6 of 7 Old 10-20-2011, 11:30 AM
superduty4x4's Avatar
I'd contact Joey at Terminator Engineering and see if he'll still take yours as a core, then get one of his T500 pumps.
I know a guy in Orting who may have an HPOP, or could help you find one.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #7 of 7 Old 10-21-2011, 05:04 PM Thread Starter
thanks for all the help guys. i will reply when i find one.
