wont start no smoke - Ford Powerstroke Diesel Forum
Old 10-14-2011, 08:59 PM
Unhappy wont start no smoke
i have a 95 powerstroke F-350 dually 4x4 5 speed i pulled up to my house shut it off and the next mornin went out to start it and turned over fine but wouldnt crank, no smoke nothin would run on eather but not on its own, i checked the num 22 fuse it was good, changed the crank sensor, changed the hpop, changed the icp sensor, changed the irp sensor, changed the injector control module, changed the pcm, still nothing, i have tried to plug in two different scanners and all i get is, failed to link to computer. does anyone have any ideas or know of something that i havent thought of ? this thing is eating my lunch!!!! any help will be greatly appreciated thanks
Old 10-15-2011, 08:27 AM
How's the main oil level? How's the level in the HPOP reservoir (if you do need to fill it, does it just keep draining down after trying to start it)? Was Fuse #22 checked with a meter or just visually? Check Engine light on? Wait-to-Start light coming on? What's your fuel pressure when cranking? Even though the CPS was swapped out, is the tach registering when cranking? Do a real good check of the fuel bowl wiring harness as diesel fuel can really do a number on it and cause lots of issues. After that you may need to get a guage on the HP oil rails to see what kind of pressure you're getting. Cheers!
Old 10-15-2011, 10:20 AM
the main oil level is good, the hpop level is rite at top and stays there dont drain down, the new fuse in 22, no check engine light, wait to start light on comes on and goes off, dont know the fuel pressure, the tach comes up to 300or 400 when cranking, ive been working on these things a long time and never ran into this before its got mme puzzled
Old 10-15-2011, 02:26 PM
ummm if the fuse is good, mayhap the wire has come in two ? cranks but no juice to PCM ??
Old 10-15-2011, 03:07 PM
well im getting power to the pcm it cranks and is smoking now dont know what i did moved something i guess???? but still wont start it acts like i get power to the injectors for just a second when i first start cranking on it to make them fire once then it acts like it loses power again does that make sense?
Old 10-15-2011, 03:09 PM
Failed to link on both PCM's or just the new one? Swap if only the one. Change your fuel filter? May be clogged.
Did the ICP sensor have oil in it? The plug may be "shorting" out. Try shooting contact cleaner in the plug then leave unplugged then try to start.
Old 10-15-2011, 03:19 PM
well it has a new filter the plug on the icp is clean i checked all my connections im getting good oil pressure comes very quick while turning the engine over i took the fuel heater out of the fuel filter bowl as i live in new mexico and it is hot all year round is there any sensors that would cause this besides the cps? or is there any other wires that have the tendency to burn in two or something im missing thanks for all the advice
Old 10-15-2011, 06:56 PM
Glow plug relay? Glow plugs?
Old 10-15-2011, 07:53 PM
UVCH maybe? GPR and GPs won't cause a no start. Just hard cold starts.
Also, gotta be a good scanner to link to these trucks. Not sure what kind you got.
Old 10-15-2011, 09:35 PM
do you think it could be uvch? i wouldnt think both sides would screw up at the same time but this dam thing has me puzzled ill take them off in the morn and check them, my snap on scanner has the right cards and key just wont link up i seen somewhere on here it wouldnt work unless 95.5 and up is that true? ive never heard of that i will let you know what the harness looks like tommorow thanks for the advice
